camera makes click sound when turned on
jonathanlc2005
322
3
It's really weird... and gets little warm around 107 degrees but is more noticeable on kick stand cause its a heat magnet. Also why does android apps crash or lag? I thought we got a powerful phone
the clicking is the lense(aperture?) opening in the camera as far as I know.
I do have a click sound when the camera goes off and on although it is not consistent...Was just wondering if anyone has this. I didn't notice it when first using the Evo. It's just recent. It does originate near the upper portion around the camera lens and light area. Anyone else?
I wondered about the aperture, but as it is not consistent and the amount of sound varies...I've tested in the same conditions to know this..
It first became of note when I used Google Goggles recently...then it has happened everytime since.
The clicking is not normal. Mine just started doing it a minute ago on my Evo that I bought on launch day. First it said it couldn't save pictures because I didn't have permission to use the SD card or something like that. I rebooted, no SD card messages but now I get a clicking sound.
Mine does it when I back out of the camera app. If I reboot the phone, it doesn't do it anymore for a bit. After I go into the camera app and back out a few times, it starts to click.
It's normal.
I have 4 Evos that I bought on launch day. Only 1 of the 3 is doing it. That 1 that is doing it, just barely started a few minutes ago- over a month after buying it. And even then, it is only intermittently doing it. If I reboot, it doesn't do it anymore. The phone also gets pretty warm when it happens. And it only started doing it after I got some error when I tried to take a picture saying I didn't have permission to write to the SD card or something like that.
It is not normal.
It is not normal.
have you done the OTA updates on all the phones? the SD card issue was fixed with the first OTA update.
mine does it, not causing any problems so far.... took over 300 pics at disney world last weekend
mine does it. just download/install Layer. it does it in that app as well, when you start it up.
From day one, my camera has always made a hardware clicking sound whenever the phone goes to access the camera. It's never affected me taking pictures in anyway.
To me it's normal.
The click sound is the auto-focus adjusting the lens position. All auto-focus mechanisms make noise because there are moving parts.
There's not much room for a motor so some camera phones with auto-focus use piezoelectric strip in order to move the lens back and forth. You run current through it, the strip heats up and changes shape which can finely adjust the lens. If the camera is on the warm side, the strip can heat up and change shape on it's own and can move the lens when the camera is off, and when you activate the camera, the piezo strip engages the lens and moves it back into proper operating position (click). When you exit the camera and the phone is still warm, it might disengage snap back into that resting position (click).
The lens is allowed to float when not using it so that temperature fluctuations don't wear it out faster from pressure that would build up from locking it into place.
I noticed my camera was making this sound yesterday for the first time. It doesn't seem to effect the performance of the camera or phone however. Hopefully it's not a gradual thing.
Well mine doesn't seem to be doing it anymore. I guess it was just a fluke thing that only lasted a few minutes.
vwssimalino
