I can start a video and after about 9 seconds it will stop then return to home screen. Also sometimes taking a picture it takes about 5 times hitting the shutter before it will take a picture.
Anybody??
Welcome to Android Central! Is it saving to Internal Storage or the external SD card (if the latter is even possible)? If it's trying to save to external SD, try changing to Internal Storage. If the SD card is bad or corrupt, it might be causing this problem.
