B bjballar41 Well-known member Oct 23, 2010 215 1 0 May 28, 2015 #1 When I take a pic it seems like it takes forever for it to save the pic and load to take another. Is anyone else's like this
B. Diddy Senior Ambassador Moderator Mar 9, 2012 168,877 9,921 113 May 28, 2015 #2 Is the photo saving to Internal Storage or the microSD card?
N nodnarb1974 Active member May 8, 2013 38 0 0 May 28, 2015 #4 I noticed the same thing and had it saving to the external SD card. Once I switched it to the internal storage it saved a lot faster. Posted via the Android Central App
B bjballar41 Well-known member Oct 23, 2010 215 1 0 May 28, 2015 #5 I wonder if it's the speed of the card or something
B. Diddy Senior Ambassador Moderator Mar 9, 2012 168,877 9,921 113 May 28, 2015 #6 What class is the card? If it's Class 4 or something low like that, it can take a little longer for read/write operations. But the other possibility is that the card is corrupt or failing. Can you test out a different card?
B bjballar41 Well-known member Oct 23, 2010 215 1 0 May 28, 2015 #7 It's a transcend premium 300x 32GB HCI. Doesn't say class but I wanna say it was higher than 4 at least
