Camera360 Ultimate problems
splmonster
1,117
138
Not sure if anyone uses this app.. But was wondering if anyone had this same error on the newest version.
"Camera initialization error, you can modify the resolution under this mode and then restart your phone to try again"
Does this when I try and set it to 3264x1952 Widescreen which is the same resolution as the stock camera app. Any reasons?
The best advice i could give you with this is to contact the develpoer, let them know the details surrounding the error.
Also let them know your phone model and what version and build of android you are running. hopefully they will get back to you ASAP
Yeah that's what I did, they said they will work on the issue.
Pull that battery and press the power button! Drain it, press the power button, and hold it! Make sure your SD card is pulled as you don't want to de static it and kill it! Yes sir drain that phone SD card free and boot!
Great, im glad they are working on it, its great when developers take the time out to respond and work on issues like that.
Good luck, hope they fix that up for you
kankuraon
