Can an Android box w/USB 3 run 1 GB Lan at near max speeds with adapter?
  • Start date Start date
A
Android Central Question
I am seeing few TV boxes that support 1 GB LAN. I was thinking if I purchase an RJ45 USB 3 adapter would it be recognized by the Android box and have speeds higher than the default 100 Mbps limit by the mobo or controller?
If you're buying a USB 3.0 network card that is advertised as having a certain network speed then it's likely you'll get that speed. USB 3.0 can support up to 5 Gbps, plenty for giving you a 1 Gbps LAN connection.
Now, will the OS actually recognize the adapter? Possibly, but I can't directly answer that.
If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
r3dpuk3
