Can anyone help me with the volume on my Android Bluetooth, it's been low since I updated?
  • Start date Start date
A
AC Question
android blutooth volume low since update...
I went from a Motorola Droid to a Samsung s5, my volume issue started with the first and continues on my current s5. I used to pair my phone to a speaker on my bike and it was great. What I remember is an update occurred and the volume on my speaker is more than cut in half, on two different (but same model) speakers it's the same issue. When the 3.5 cable is used volume is what it was before the update. In my trouble shooting ive tried apps to no avail adjusting the volume, trying to adjust on the settings menu, and while paired taking the volume all the way down and back to max. The results are all the same and the speaker volume is just not half as loud at max paired over blutooth compared to physically plugged it. Outside of rooting is there any fix for this??? Thanks.
amaka
