Can i Change the battery of MI A2 with other higher mAh battery of same size
  • Start date Start date
A
Android Central Question
I have Mi A2 that has 3010 mAh battery I wants to replace it with a higher mAh battery with same dimenstion is it possible if show how can i know which battery can be fitted it into
Device manufacturers have gotten pretty good at getting the maximum capacity from batteries of certain dimensions. That said - devices are so tightly integrated that you are unlikely to find a battery of a larger capacity to fit inside your phone and connect properly.
