Can I get some help with a battery issue?
amit ja
3
battery issue
I am using htc 820 dual sim phone its having big issue of battery . Draining even data off n screen is off when i find out that background aap running when screen is off its showing 70%, 75% used by androide os plz help me...plzz
Re: battery issue
70% to 75% of how much being used? 75% of 1% of battery use is great. 75% of 90% battery use is terrible.
The lines you're looking at are the percentages of the total amount used by each app, they're not the percentage of battery capacity being used.
musictheory
