Can I get some help with a music playlist problem?
DerrikM
18
Music Playlist Problem
On Kit Kat Verizon G3. Had to do a factory reset and format my SD card. Everything works perfect except for playlists through the stock music player. All of my music is stored on my SD card. The stock player plays and lists music as expected but does not show any playlists at all. Google Play app shows all of my playlists, but I cannot find a copy of them anywhere on my phone.
Is there anyway I can export or download the Google playlists from the cloud to my phone so that they will work with the stock player? Also, I have some playlists on my laptop that are used by Windows Media Player, they are not up to date, but better than nothing. Can I just transfer them to my phone and put them in the Playlists folder?
Thanks
Re: Music Playlist Problem
Thanks
Give this app a look and see if it does what you want.
https://forums.androidcentral.com/e...d=org.ssi.playlistbackup&hl=en&token=D3iAPj7W
Nicoloks
