Can I get some help with a Power Bank charging question?
  • Start date Start date
A
AC Question
Hi I am waiting on receiving a USB power bank which uses 18650 battery, so I have bought 18650 rechargeable battery.
My question is say I go out and use the power bank til it dies (battery), and get home and wish to re-charge the battery.
Do I have to remove the battery and charge elsewhere, or can I charge the battery through the same unit is installed into say using a USB cable, or mains mobile charger?
Thanks
Re: Power Bank charging question
Thanks
Welcome to Android Central!
You would just charge it with your phone charger or the charger it came with. There is no need to remove the battery from the case.
CathyAus
