Can I get some help with an sd/external card mount problem!?
  • Start date Start date
A
AC Question
hello,
please i need some Help!
gt-19295 on lollipop 5.0.1
the problem started that whatsapp stopped downloading media,and when i try to download it say there's no enough space,even that there were enough space.
i don't know what started the problem!! but maybe after root!
i did some changes to platform.xml ..
but know the problem extended to,
all apps stopped working ( cause they can't reach sdcard maybe) even i can't start helium to make a back up!
even "my files" say that there's no files ( not seeing internal or external card)
and es file explorer when choosing sdcard say "cannot start streaming server"
but root explorer can explore files from /storage/emulated (external and internal)
i 've unrooted it and restored the original platform.xml
downgrade it to kitkat and re upgrade it
cleared cache partition
nothing worked!
please what could be the problem ? and how to fix it?
sorry if i didn't make it so clear , cause im not so fluent in English.
and thank you for reading.
P.S when i was flash a firmware it was restore the custom status to official ,but now it stay custom !
I've deleted the platform.xml ,and it's regenerated after flashing,
so I went mad and deleted the whole permissions folder under system\etc..
and it does regenerated also!
the f*** weird thing is that the android file explorer "my files" Is doesn't seeing internal&external!!
Note: i was have Xposed Framework and AppOps module ,maybe after rooting lollipop they were not compatible and caused problem?!
Is there any files i can delete replace or anything to solve the Problem!!
There's noway I can reset system settings and keep personal data!
(apps data contacts messages..)
removing-replacing-editing files using root explorer?!
cause this is the only thing works now! :T
and i don't wanna to do factory reset ;(
ManboaMaleManboaMaleEnhan
