Can I get some help with my LG G3 screen problem?
Dimitris Sitas
LG G3 Screen Problem
Hello i have LG G3 and i cracked the screen so i bought a new one from ebay , then when i got it ive installed it perfectly but when i open it white vertical lines appear, when i double tap the screen it closes and when i open it again it works perfect for 1 second and then colors start to fade and vertical lines again appear,ive contact the ebay seller to send it back but i want to ask if it sth wrong with the installation or the new screen has the problem
Re: LG G3 Screen Problem
Sounds like the screen itself has a problem. Hopefully the seller takes it back because if you damaged it during installation...
hii
i have the same problem.
some one tha a soultion for that?
Thanks
Damaged LCD screen. You can try a warranty replacement but they may claim user damage. Next best option is to buy a screen replacement, they are about $100 - $120 USD online. it's an entire assembly replacement including the digitizer so no need for tricky installation and glue separation with heat guns.
MO Shm0
