Can I get some help with my Verizon LG G3 HD advanced calling?
RoadDawgBob
Active member
Aug 6, 2014
32
Verizon LG G3 HD Advanced Calling
This morning, I was messing around with some phone settings, and saw the HD Advanced Calling option. I read into it a bit, just enough to realize this wasn't going to add anything to my bill, so I enabled it.
After a few seconds, I got a message that said to restart my phone in 5 minutes to start using the Advanced Calling. So I restarted the phone.
This, then, changed my dialpad so that it looks completely different. It made it so the bluetooth button for that call changed to be in a settings menu now. I tried to go back to what it was before, but all I can do now is disable the HD Advanced Calling. Doing sio doesn't change my dialpad back to what it used to be.
Is there a way to revert back without redoing my whole phone?
Re: Verizon LG G3 HD Advanced Calling
I took my phone into a Verizon store to have them look at it. A tech in the back set my phone to the default settings and this fixed it.
Doing this made me reset all my preferences, but this did NOT cause me to lose any pictures, apps, or anything like that at all, just the settings that I have changed since I bought it.
Hope this helps anyone else that this might pertain to.
jammy09
