- Jun 26, 2015
- 331
- 15
- 18
Freezing / Lag Issues
Well I'm about to start the process of trying to find out what apps are causing my performance issues and wanted to see if anyone knew of the best way of going about this. Is there some system monitoring apps that you might recommend to help me determine what is causing the issues or am I stuck removing or disabling apps randomly until I find the culprit. Thanks for your suggestions.
