Can I get some help with some Samsung/Logitech sync issues with Android 5?
  • Start date Start date
A
AC Question
Samsung/Logitech Sync Issues with Android 5
I have a Samsung Galaxy Note Pro 12.2 with a Logitech keyboard. As you already undoubtedly know, immediately after the 5.0 auto-update the keyboard stopped communicating with the Galaxy. This is a huge inconvenience because I use the Galaxy in my business. When will a fix be available?
Re: Samsung/Logitech Sync Issues with Android 5
Samsung is supposedly working on a fix or update to 5.0.2, but you could always do a revert back to 4.4.2. The only thing is that you'll have to do it as a firmware install with that particular ROM from Samsung and then you are back to square one and will have to re-install all your apps.
Posted via the Android Central App (with my BlackBerry Passport)
I gave up/broke down and bought the Samsung keyboard.
wobblefix
