- May 12, 2015
- 1
- 0
- 0
[Q] Help - TV110 (S805) Partition Problems
I have a TV110 (Amlogic S805, 1gb/8gb) Android TV Box. I was trying to replace the stock ROM with Openelec v5.0.8 from Kerber. The update went fine until it rebooted to launch Openelec then it hung at the Openelec logo for over an hour. I thought the box was hung so I removed power and rebooted. It hung again in the same place so I decided to use the reset button to launch recovery. I must have cycled power too quickly because it would only show the boot logo and would go no further. Something was seriously wrong with the box.
I created a bootup SD card with TWRP recovery on it. I booted up into TWRP 2.8.6 without any issues but could not restore any of the partitions. TWRP was getting errors trying to mount all the partitions. I figured I could go back to stock (I have a NAND backup). When I try to wipe or restore it fails because the partitions are not mounted. I tried to install the old firmware using the install from TWRP and I get "Error executing updater binary in zip".
At this point I am stumped. What do I do next?? How do I get my box bootable again?? Can I somehow re-create the partitions??
Any help would be appreciated.
