Can I get some help with wifi issues with my G4?
ReddWings
4
Wi-Fi Issues with the G4
Hi, I went from a Samsung Galaxy S4 to an LG G4, when running the facebook app or tumblr app the images take forever to finally load and by forever i mean minutes. I don't seem to have this issue while at work on wi-fi only at home. Must be the network at home right? I would agree except that on the S4 it works fine. Is there a setting on the phone I should look into. any advice or help is greatly appreciated. By the way, if i disable wi-fi on the phone and use the LTE data it works fine.
Thank you,
Also have issues with some games while on wi-fi as well. :confused:
Re: Wi-Fi Issues with the G4
Thank you,
Welcome to Android Central!
I would check the security on your router and see if it is causing an issue.
+1 for router settings. Then reboot it
alanmagdaong
