A
Oh so Samsung works. What about other brands? Do you know?Yes you can... get USB C to USB OTG cable and plug your printer in... start Samsung's print app and it'll get you connected, downloaded, etc. Unless you have an older printer, you should be good to go.
Good Luck
You said a Samsung printer will work through USB adapters. But what about say a Brother or HP Printer? I have an old spare Brother printer here that I can repurpose for phone/tablet use in the living room. It's pretty old though. 2012 I think.chanchan05 to what are you referring? Software, hardware, brand?
I have a Samsung phone, so Samsung printers will probably work fine. Maybe I'll jusy try it out.Ah... no I was referring to phone brand. Printer brand... depends. I've used epson, hp....
Good luck.
Need help please non wire less printer from galaxy note 8
Can you join the network the printer is on? Is the printer on a network?
If so, you can print to it. The app Printer-Share is great for printing to a networked printer.
