Can I use a "Power Injector" from a car adapter to enable "quick charge" from my USB port?
Nathan Greenfield
When connecting to the built-in USB port on my car (that allows for Android Auto) I get a "slow charge" -- if a charge at all (I think I'm actually losing power). Does anyone know if I use a cable (like this: https://www.amazon.com/HIGHROCK-Enhancer-Female-Charge-Extension/dp/B00NIGO4NM) to safely boost the power to enable "quick charge" on my phone while running Android Auto?
Re: Can I use a "Power Injector" from a car adapter to enable "quick charge" from my USB port?
Welcome to the forums. I am not sure that will work. What phone do you have, and do you know the amp output of the USB port in the car?
Make sure you are using a charging cable. Install Ampere, it will tell you if you are doing USB or AC charging and how much current you are pulling.
It depends on the head unit you have. I tripped out my 8100NEX by using a high charge cable with my 5X which pulls 3A. Back to a 1.7A cable and everything works, with a normal charge.
When connecting to the built-in USB port on my car (that allows for Android Auto) I get a "slow charge" -- if a charge at all (I think I'm actually losing power). Does anyone know if I use a cable (like this: https://www.amazon.com/HIGHROCK-Enh...ag=hawk-future-20&ascsubtag=UUacUvbUpU5266455) to safely boost the power to enable "quick charge" on my phone while running Android Auto?
I've tried all sorts of cables and nothing works.
Not sure if what car you have, but my Hyundai Sonata 2015 can't change my phone with the built in usb. It is actually losing charge with Android auto running. The usb port is made to charge ipods and that's it. Hyundai has even admitted this, but keeps reusing their underpowered usb ports in every new iteration of their cars.
