Can unlock my phone ater being on charger..PLEASE HELP
NHBass39
840
7
I have to do a battery pull to get it to unlock anyone know why this would be happening? This has happened to me twice so far.
Sound like the digitzer locked up in that section... I've had that happened a few times but i think i was running Venom when it happened. Yes a battery pull has to be the fix
I'm all stock though. Should that still happen every time I pull it off the charger?
After the Reset does it work fine until you pull it off the charger? If it does it sounds like a software issue and you know what i say to software issues :)
Does this do it on ALL chargers, or just one? It sounds like you have a defective charger that is under/over volting the digitizer, causing it to look up... I have had similar problems with "cheap" brands or chargers that have just failed, the screen becomes unresponsive.
If it is on multiple chargers... well... ***cough*** Factory Reset ***cough***
Yes. Thing that bothers me is everytime I charge my phone I will be going through this. GRRRRRR!
Stock HTC charger. I'm going to try my wifes HTC charger and see what happens. I'll post my results. Thanks for the help. :)
Verify the charger is rated at 5V/1A or better, if she has the same phone it shouldn't be a problem, but not all HTC's use the same charger.
Khalequzzaman
