Can't Activate Device After Factory Reset - HELP!
melanie_jane
5
Hi,
I'm new here and I'm not sure if I'm posting to the right place but I need some help. I have a rooted Sprint Galaxy S3 running KitKat 4.4.2. I'd been trying to install CyanogenMod with no success.
At some point I did a factory reset of the phone and decided not to continue with the CyanogenMod but I had ClockworkMod recovery on my phone and decided to restore to it.
Immediately I started getting errors that gapps and a bunch of other apps stopped working...I couldn't do anything so I booted into recovery mode again and did another factory reset. Now I can't activate the phone.:'( Any help would be much appreciated.
Hi,
Welcome to the forums.
I would clear cache in recovery and do one more factory reset, and see if that helps.
Thanks for that. In my travels, I think I found what the problem may be - I need to restore my IMEI? I've been looking for a tutorial on how to do it with little luck. Could you help with that?
Unfortunately, no. I have no idea how to do that.
From a Carbon M8 and AC Forums app
Twousay
