Cant get System UI tuner.
lilnate
111
5
So ive read you just need to long hold on the settings gear in the drop down menu and it'll eventually spin and unlock the tuner. Ive tired doing this for up to a minute and it wont unlock. The option is not in my settings already either. Pretty frustrating. And yes i have the 6.0 update.
so i did some digging around and found that turning off my developer settings worked. Apparently by having the animations off might have been causing it problems.
Avatar
