Jeritte Harding New member Mar 15, 2023 2 0 0 Mar 15, 2023 #1 Power button and volume button aren't working on my galaxy a13. Wondering if there is a way to power it on
mustang7757 Admin Moderator Moderator Feb 6, 2017 97,844 13,924 113 Mar 15, 2023 #2 You sure battery doesn't need charging or bad battery? Plug a known good charger fore few hours. I'll leave a Link to register so you can communicate here , As a guest account you can only post questions but can't reply. https://forums.androidcentral.com/showthread.php?t=409154 Sent from my SM-S918U1 using AC Forums mobile app Last edited by a moderator: Mar 18, 2023 Upvote 0 Downvote
Jeritte Harding New member Mar 15, 2023 2 0 0 Mar 18, 2023 #3 It's fully charged. Buttons don't work Upvote 0 Downvote
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,275 10,549 113 Mar 18, 2023 #4 Try pressing and holding Power for about 30 seconds. Is the phone still under warranty? I made you the owner of the original guest post to make it easier for you to find. Upvote 0 Downvote
mustang7757 Admin Moderator Moderator Feb 6, 2017 97,844 13,924 113 Mar 18, 2023 #5 Jeritte Harding said: It's fully charged. Buttons don't work Click to expand... How you able to tell it's fully charge when it doesn't power on? Sent from my SM-S918U1 using AC Forums mobile app Upvote 0 Downvote
