Can't turn off double tap power button to turn on camera!
Postoid
242
4
This evening tap settings and at the very top I see a "suggestions" bar. It says enable double tap power button to launch camera. Ok, I'll try it and if I don't like it, I should be able to turn it off. I'm on 8.1.0 Nexus 6P.
Checked the net for "turn off double tap power button to launch camera" Went to "settings" > display > and nothing there on my display screen showing you that it can be disabled. I'm stumped. Help.
Ha..found the answer. In the search bar at the top of the phone I typed 'Jump' and this came up :
Jump to camera
To quickly open camera, press the power button twice. Works from any screen.
System>Gestures> Jump to camera.
Hope this helps someone :)
Jump to camera
Thanks bro! It was making me mad.
jqlen
