• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Can't understand why Android system is using 30% of my battery
thegame161
1,298
Just makes no sense. Can't quite work why it's using so much.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,278
20
Try a reboot and see if it helps for tomorrow. Might be a wake lock issue.
Sent from my T-Mobile Note 3 using AC Forums.
z06mike
795
You're on track to get ~5 hrs screen on time. That's pretty good if you ask me. If your screen on time were a lot less then I would be worried.
Sent from my SM-N900V using Tapatalk
thegame161
1,298
Well I switched wifi and data off when I went to sleep so I'm at
2 hours, 5 Mins screen time
15 hours total
With 48% left
z06mike
795
Do you have location settings turned on? Google Now? Wifi always scanning?
