Can't use cm 10, md5 not foud error and stuck on reboot (using twrp v2.3.3.1)
Cloud64
This is my first time trying to do all this complex stuff with my phone. Anyway I ran into a problem trying to use cm 10 because of some md5 file not found error. And when I try to reboot my phone gets stuck.
After rooting its best to download cm 10 from their website and make sure its for HTC one x att or international so don't mix them. And copy it to your SD card and restart choose to install from SD card and install . there shouldn't be any problem
Sent from my One using Tapatalk 4 Beta
Hi! so exactly which cm are you using 10.0 or 10.1? Which One X is it? Which logo screen are you stuck on? Can you still access bootloader? Please give all the steps prior to this event.
If it's a nightly, it won't have an md5 sum to check. You need to turn off signature verification checking.
Sent from my SPH-L710 using Tapatalk 2
i have a galaxy s3 on boost mobile i have twrp recovery and when i try to flash kitkat rom or any other rom i get md5 not found. please help
twrp 2.6.0.0 i uncheck the md5 option but it dosent work. the only rom that works is the hyperdrive rom but i cant get 3g or 4g network
RichardDixon
