Captivate FAQ's/Known Issues - Please Read Before Posting
Status
Not open for further replies.
Cory Streater
9,490
3,428
The following are frequently asked questions within the Captivate forum. This page will be updated frequently, and suggestions are welcomed. Please PM an Admin or a Mod if you have a suggestion or would like to add additional content.
Documentation:
1. User Guide.
2. Samsung Support FAQ's.
3. Exporting/Importing contacts from Blackberry, Windows Mobile, Palm and other devices into Android.
4. Android Central's How-To Articles.
Popular Discussions:
1. Task Managers.
2. Tethering.
3. Wallpapers, Ringtones, and Themes.
4. Best apps.
5. Cases.
6. Performing a backup.
7. If I exchange/replace my Droid for a new one, will everything be transferred over?
8. Favorite music apps.
9. Sync with iTunes via WiFi.
10. Other iTunes synching methods.
11. Where to store custom notification sounds & ringtones.
12. Converting movies using DVD Catalyst (Original Droid settings also apply to X) or Handbrake.
13. Everything you need to know to uncripple your Captivate.
Known/Common Issues:
TBD.
If you do not see an answer to your question above, please use the SEARCH feature of the forums, to look for a solution, before starting a new thread.
WPA2 Enterprise LAN issues -- possible fix
One of our podcast listeners and chatroom attendees (and I'm sorry, I forgot your name!) asked about this one.
Happen to be lucky enough to know a pretty savvy network engineer, who is also an Android geek who pointed me in the right direction just a few days ago about this one.
Depending on your specific network, it might not work. But I promise it won't be any worse than it is now :)
How to fix Android Wi-Fi problems :: SearchNetworking.com.au
Thanks to the good folks at Search Networking, and thanks Dave for pointing me to it.
Thanks for slogging this out, AmsDiane! I too had the apk file in the payload directory and got the same error. All is good now.
Id love to find more as well...best I could come up with was Trillian and Sirius.
can some one help... me plz if they can ... plz reply to my aim at starsxbroken
thank you so much for in advance..
If you use kies, will it let you do your software updates on it from samsung's website? I uninstalled kies from my computer because it said my device was not supported or something like that.
I have, FINALLY, got it to work on my Vista 64 bit machine, downloaded the USB drivers for 64-bit systems here, removed the Samsung Drivers first, of course. The USB connection is rock solid and instant now that I switched to a USB port at the back of my machine. It was always hit or miss, mostly miss, with the front ports. Removed SWM v1 and replaced with v1.1beta which turned out to be a good thing since v1 always gave me a fail message it seems it did put the .apk on my phone, whether it was all or part I don't know since I did not try it, but, since v1.1 has the UPDATE check box it overwrote the installed .apk and now AndroidWifi Manger, it's .apk and the PC part work fine and I'm able to sync and back up my phone, since Kies has never worked for me.
Thanks everyone for the information that helped me to trouble shoot everything and getting SWM to work!
i keep getting this result or something similar:
"Installing application
1201 KB/s (2122619 bytes in 1.725s)
pkg: /data/local/tmp/to_install.apk
Failure [INSTALL_FAILED_MISSING_SHARED_LIBRARY]
#### Called register_android_provider_MediaStore()
If you do not see an error, everything was
successful and your application is installed.
After exiting the program, you may unplug
your Android phone.
Press any key to continue . . ."
how do i get these libraries and where do i put them
load apk files from pc to phone
im rooted and have sideloader fix installed but dont know how to install a apk file/program from my pc :p
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Assembly Version: 4.0.0.0
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box. the error log net framework 4 is installed
Status
Sonfollower28
