Car Bluetooth speaker with Audible?
ctychick
336
3
18
Of course I use my car Bluetooth for phone calls, but is it possible to use the Bluetooth to listen to a book in Audible through the car speakers? If so, what is the process to make that happen? Thanks
Sent from my ADR6425LVW using Tapatalk
It should be possible. So long as you have a TTS engine (PicoTTS should be installed by default), just tell Google Books or whatever app you're using to read the book. The phone should be treating the bluetooth radio as a stereo headset.
Your car stereo has to be A2DP compatible. A lot of the earlier ones can do standard voice calls but transmitting music/audio uses a different protocol which might not be present. Check with the car / stereo manufacturer.
gerryreed39
