Car Dock sound with Pandora and other apps
Hardcore73
84
8
In case anyone else has a problem playing your sound through your aux port in your car using your car dock you have to play the app (Say Pandora, pause it). Dock your phone or launch the car dock.
Click the audio button (looks like a phone), changes to a speaker.
Hold your home button so you can go back to a recently used app and click play on Pandora.
I also found if you use the Voice search command and do a "Listen to: "artist" command it will also launch Pandora and play through your car speakers.
Reactions: Nchaka
Another option is to use a different car dock app (I am using Car Dashboard) and then install Galaxy Dock Sound Redirector. This will send the audio to your car speakers without the workaround.
i was wondering why i had to plug into the phone and not the dock. thought i was crazy. so do you need the dashboard app or can the sound redirector app work alone? and does everything else still work like speakerphone and speak to text?
ladakh
