Car mount for N4
valpd
249
I'm looking for a car mount for my 05 Highlander. I tried the Bracketron MI-T mount and the Mountek N Groove CD mount, but none have set up some basic expectations. I need something that won't shake, un-stick or block the view of my radio.
Doyer, so how exactly does it stick to the dashboard?
I don't trust suction cups at all. I like this SlimGrip a lot.
The car mounts have specific look and dimensions which avoid any kind of damage while driving on uneven or dusty roads. Car mount have suction cup with lock clip which keeps your phone safe. You can fit this car holder on desk or in window easily and install it on your car. It is free of 360 degree rotation. After removing the car mount, no mark left from the car mount on that particular location. You can easily plug-in your charger into your phone.
