Car Mount for N7
dsneedmd
206
I need to mount my N7 in my car to use as a 7" GPS. Can you recommend a mount you have use and like?
I have no suggestions, won't get mine until Christmas anyway. But...why would you want a 7" device as a GPS? Wouldn't this impact your visability driving? Seems like a safety hazard. Just use your phone :)
I drive a prius and it has a largish display (about the size of an N7) in the center of the dash above the the radio. It has a very sh*tty GPS/Map system. Not only is it fugly but the UI is horrendous (it comes with a 200 page manual, take pages to explain how to set up a route, for example). I pretty much avoid it like Justin Beiber, preferring to use my android phone with GMaps/Nav. But it's actually not a hazard at all if I use it. The phone is much more of a hazard, mainly due to it's size. I would love to use an N7 for Nav in my car but there really is no convenient place to put it. I would love to rip out the existing screen and use a 7" android device in it's place.
Thanks for the reply & link! Having problems visualizing how the various parts would go in my car. Have you bought a whole system for your N7 to use it in your car?
Has anybody tried the "As seen on TV" GripGo? Two for $15, and I *know* it'll also work with an iPhone when I'm hauling that...
I got this one from Amazon: Amazon.com: iKross Car Dashboard Mount Holder for 5" - 10" Smartphohes & Tablets: Apple iPad 2, 3, 4 iPad Mini, Acer Iconia Tab A500, A700, W510, A210, A110; Asus Eee Pad Transformer TF201, TF300, Infinity TF700, VivoTab RT Tab; Samsung Galaxy Tab 2,
It works well, only gotcha is that the base is large and you must have a flat service that large for it to hold. The top of my dash would not work but I found an area on the side of the dash. Appears to be very strong.
Does the rotating arm holding the Tablet lock into place? I recently bought a mount and the tablet freely rotated with no provision to lock the preferred angle.
Yes, has a locking nut that you tighten as much as you need.
I like the suction winshield mount on wanpool, you can change the view angle 360? , it perfectly fits in the case, and stick very secured as I tested.
rabcd
