KoukiFC3S Well-known member Oct 9, 2009 1,723 123 0 Nov 16, 2011 #1 It fits perfectly once you remove the insert on the car dock. Sent from my DROID RAZR using Tapatalk
Davenurse Well-known member Mar 16, 2011 85 7 8 Nov 16, 2011 #2 Thanks for the info, I was going to try this myself but was afraid it wouldnt fit properly. Going to get commuter case tonight!!
A azhalvy13 Member Nov 6, 2011 9 6 0 Nov 17, 2011 #3 Do you happen to know how it works with the HD dock?
Davenurse Well-known member Mar 16, 2011 85 7 8 Nov 18, 2011 #4 Went to get the case tonight and as you said once you remove the insert on the car dock it fits perfectly, thanks man that was a great find!!! Sent from my DROID RAZR using Tapatalk
