Car mount that accommodates a case
  • Start date Start date
A
AC Question
Hi. I'm looking for a car mount that can accommodate my Galaxy S5 while it's in its Incipio case. I can find plenty of car mounts, but not one in which it fits with a case. Also, I'm not interested in a universal case, it has to be a dock for the S5 because I have an app, Tasker, that I'd like to program to recognize when it is docked in the car. Does anyone know of a car mount that fits these requirements? Thanks.
Docks are designed to fit the Device itself. If a universal is not an option then remove the incipio case. You do have choices, just a matter of the lesser desired.
Sent from my Nexus 5 using Tapatalk
I use the ibolt with my note 2 in a rugged case. No need to take the case off.
Sent from my NX785QC8G using Tapatalk
Docks are not always designed "to fit the device itself." Encased makes one that accommodates a case (but doesn't dock, just mounts the phone). And, to be clearer, I am looking for a solution where I do NOT have to exercise the choice of removing the case... if that's OK with you.
I'll check out the iBolt. Thanks for that suggestion.
Twousay
