Car quick charger while using navigation
MHBlink8
318
10
Whenever I am using Google Maps for navigation and I plug in my phone to my quick charger, it doesn't actually charge the phone. It just keeps the phone at the same charge level, but never actually charges the phone. I know the charger works, because if I'm not using Google Maps, the phone charges as expected. I'm using a 3rd party quick charger, but that shouldn't matter.
Is anyone else experiencing this?
I don't believe a car can actually put out the necessary amperage to charge the phone when using navigation with the screen on and at full/near full brightness. It never used to work on my old S3.
Sent from my SM-P600 using Tapatalk
The car charger I got when I bought my Galaxy Nexus from Verizon charges my S6 while using Waze for navigation. I drove for 45 minutes yesterday, and the phone went from ~60% to 100 before I arrived at my destination.
I know you can purchase chargers on amazon that do make use of quick charge capabilities.
I have a Quick Charge certified car charger too and if the screen is on and using Google Maps Navigation then it will barely charge. You're not alone there. Actually, my S6 will actually say it's getting too hot and needs to cool down!
My car charger is not a quick charger, its at least 3 years old. I have my phone mount clipped onto one of my cars AC vents to keep it cool. I wonder if that has anything to do with it?
Just sounds like your phone is eating up just as much juice as your charger is putting out.
That sounds like a great setup. Heat is never your friend.
Sent from my SAMSUNG-SM-G920A using Tapatalk
It's worked great for me so far. I switch it up in the winter and go with a window mounted option to keep it away from the vents.
I have an anker car charger, 2 port, with a charging cable only (not the usb data/charging cable). Running the phone with GPS and the screen on it still charges my phone to 100% even with everything running.
Make sure you have a good car charger with enough power and a charge cable only.
gianfranco
