Case Problems Help
sonic1519
14
Love the Note3. So i picked up a wireless charging plate and a back cover in black so
i could take advantage of the wireless charging. Anyway with the new back cover which
is just a tad thicker than the EOM cover i can't find a good case anywhere. all the ones i tried
just a tad to small. the eom cases were made to fit tight so theres not a case in site.
anyone else going through this if so how did you solve it.
sforsyth01
373
I have the same problem. I haven't found a solution. The UAG case is the best fit I have found and it isn't close to perfect.
I ended up buying the S View cover that has built in wireless charging. Case and back cover in one. But I'm not 100% happy with that solution either.
-Shawn
Noting the world one S-Pen at a time
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,109
200
63
The Trident Kraken ams fits decent. The only issue is that the charging flap is a little ajar.
The caseology didn't fit
The otterbox commuter, Fintie, and incipio dualpro inner shells fit, but the hard outer shell didn't fit.
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
