Case name:
MoKo Slim-Fit Case
Purchase link:
Available through Amazon.com
Multiple colors available. Link above is for red which was used for this review.
MoKo Slim-Fit Case
Purchase link:
Design:
This case provides a great deal of protection while still maintaining a very slim profile. The Nexus 7 is held snugly and securely within six soft clips along the top and bottom. The two clips along the inside corners pop on and off to allow you to set the Nexus 7 into landscape orientation. There are two grooves along the inside of the cover which the Nexus 7 sits comfortably on. These two viewing angles, plus a third if you lean it against the clip, provide very comfortable setup. A built-in magnet in the flip cover provides sleep/wake functionality which has worked properly 100% of the time. The inside of the case includes a handstrap for use when holding the device one handed as well as an elastic strap to hold the cover open when flipped around the back. As seen in the pictures below, the device can be held upside down without the device or the case flapping around. Along the back you will find cutouts for the speaker. I did not find the sound to be muffled at all. This case, in terms of design, has not provided me with any concerns.
Durability:
The case really excels in durability. It is built very well all around. The case feels very solid in the hand and does not feel like there is any risk of threading coming loose or the quality decreasing over time.
Protection:
This case provides a good amount of protection from minor drops as it covers the front, back, and corners. However, I would not consider it to be a case to use as piece of mind if you're the kind to be a bit clumsy with your gadgets.
Visual Appeal:
Visually, I love this case. I find it to be very attractive and it definitely draws attention. And with various colors to choose from, it's easy to make your device stand out. It also does not cover the device 100% so the natural beauty of the Nexus 7 still shines through.
Overall Pros:
Very attractive design
Sleep/wake functionality has been flawless
Good amount of protection without sacrificing slimness
Overall Cons:
Not the best case for those that are a bit clumsy
Overall Rating:
I would HIGHLY recommend this case to any Nexus 7 owner.
