- Aug 15, 2015
- 8
- 0
- 0
I bought the S6 Edge the beginning of July and i bought the OtterBox Symmetry Series to go on it because it was the only one that OtterBox offered. For some reason I thought that the case had a built in screen protector similar to the Defender Series but when I received the case (I bought it from Amazon) I figured out I was wrong. I didn't think much of it and went down to the Telus store and found the OtterBox Clearly Protected Screen Protectors and bought them (for 3 times the price otter box is charging online I might add). They installed fairly easily and with absolutely no bubbles. As soon as I install my case however, the screen protector started to bubble around the edges. Especially where the sleep and volume buttons are because of the case pushing up on the screen protector. Its been on there ever since but now the whole top corner is hanging off, full of dust and dirt and needs to be replaced. My question is if anybody has found a screen protector that will work good with the OtterBox Symmetry Series case. I figured that if i bought the same brand then it should work flawlessly but unfortunately I was mistaken. I talked with one guy at The Source and he recommended I buy another and trim the edges a little bit so the case will not push up on the screen protector. If I could id like to keep the case but as a last resort I would consider buying a whole new case if I wouldn't have any problems. Any suggestions?
