Cases for S5 wireless charging cover
tacsniper
24
3
Just picked up the wireless charging cover for the S5 and now both of my cases doesn't fit because of the added thickness of the wireless cover. Anyone else able to find a case/bumper with the wireless cover?
Bumper yes but I don't think there's any.
Right now I'm just swapping the covers whenever I want to use my case.
Pro S5
I was in the boat. I'm now using the Belkin Air Protect Grip. I order the AMZER Bumper Case from ShopAndroid with my cover, but it didn't work. Went to Best Buy and the Belkin was the only that fit.
Steve
Steve
Same here. The Belkin has a poor fit with the stock cover but fits great with the Wireless Cover. :)
Samsung Galaxy S5 (Verizon)
Pro S5
There are aluminum bumpers on eBay which is out for the s5. I've heard that the Belkin bumper does fit.
If anyone know of any cases that fit with a kickstand, let me know. I'm waiting for my wireless back to come in.
Thanks.
I have a Diztronic case and it fits OK. I used a heat gun to heat it up and stretch it a little, which made the fit a little better. It's not a perfect fit, but it is usable. All of the buttons work correctly, etc. I've been using it over a week now with no issues.
Is there a case that can fit the S5 with Samsung's wireless charging cover installed?
I'm thinking about getting it. However, all the reviews on Amazon and elsewhere
said phone cases would no longer fit, due to the increased thickness of the cover.
Going naked on the phone just seems scary to me.... but I do want wireless
charging. :(
Amazon.com: Samsung Wireless Charging Cover for Samsung Galaxy S5 - Retail Packaging - White: Cell Phones & Accessories
Re: Is there a case that can fit the S5 with Samsung's wireless charging cover installed?
Your best bet is a Bumper style case. A few of us including myself are using the Belkin Bumper and it fits perfectly. The back is exposed but considering the cover is removable it's just as replaceable as a case is. Plus any heat from the charging won't be trapped.
https://forums.androidcentral.com/e...BBumper%2BS5%26cp%3D1%26lp%3D1&token=zfH2LVY7
I found that case to fit poorly but to each their own. The lip pops off easily for my liking.
Hmm, interesting. Did you try to heat the case up to stretch it? That's what I did, and it seems to be fine. Lip stays on. There is a little silver edging visible, but volume and power buttons work fine.
I went into Best Buy last night to get the bumper case. They are not restocking this item anymore. Limited to what they have on hand in the stores. Hopefully more options will pop up once the wireless back cover is reliably available.
Strange, every Best Buy around me has stock and I doubt they didn't order more. In your case though how about ordering from Belkin direct?
I'm using the incipio dual pro. It works perfectly. Came from an Otterbox defender which did not work at all
Yes the incipio dual pro... Fits with oem Samsung wireless back..... FYI they are in Stock at corporate Verizon stores.. And they let me try it before purchasing.
Has anybody tried the wireless charging cover with the UAG cases?
Sent from my SM-G900W8 using Tapatalk
I'm wanting to switch to wireless charging, but I spent the $90 bucks for a Otterbox Preserver Series case (which I really like), and don't feel like I wasted my money and not use it. I guess I can't have my cake and eat it too.
galibalmasanick
