Cell Battery Drain
tshirttan408
144
I've been watching the threads about battery life, and although mine seems strong I seem to be getting much higher cell standby than others. I'm on EE in the UK so don't have VOLTE or anything like that.
The only culprit I can imagine it to be is Instagram, as it's impossible to limit it from updating in the background (all of the special apps that can do it never even seem to be able to identify it, let alone limit it!). Does anyone else have this issue, and possibly have an solutions?
I've attached a screenshot. As an FYI at this time I only have one hour of screen on time as well.
Thanks!
What's the overall cell signal strength been like? If it's poor, that can increase Cell Standby battery usage. If the Settings>Battery graph doesn't show you the Cell Signal Strength, then use an app like GSam Battery Monitor.
Sonfollower28
