Cell standby battery drain
popkurn611
1,367
This happens quite frequently and I usually don't hit the 50% mark until 4pm.
I'm on at&t BTW. Have barely used the phone today too.
I'm in the same boat as you. Battery life sucks since June update
Posted from my 7 Edge via the Android Central App
Glad to hear I'm not the only one! It got better for a few days on the July update but then tanked again
Try a hard reset...
Telling people do hard reset or factory reset is easy but for some people doing reset is easy you could loose important documents, pictures, game profiles, music backing up all these 40gb files takes at least 2hours then after reset problem still exist this frustrates and pisses off most. So think twice before you tell people do reset
RichardDixon
