Changing camera setting to opening rear facing camera by default
alexcapone
82
Sometimes I want to capture a photo in a very quick moment and when I open the camera I want it to open the rear facing camera so I can quickly take the photo. Is there a way to default the camera setting to open the rear facing camera? I think it opens the camera that was used to take the last picture. I am looking for a way to change that setting.
Mine opens on the last one I had it on. So if you are taking a ton of selfies and close out the app on the selfie cam. It will open on that one.
it should default to the last camera setting you had open.
you may try going into app manager, camera, then delete cache and even data (which will remove any custom settings and restore to as it was when you first opened the app).
Sky234
