Changing the 'Low Battery' level?
Stwutter
553
Hi,
Is it possible to alter the level at which the G3 tells you the battery is low (currently 15% I believe)?
I'm pretty sure you can't, but in case I've missed it...
Go to Settings, General, Battery, Battery Saver, Turn Battery Saver On, open that, and you can change the charge percentage at which Battery Saver switches on.
....If that's what you mean. I'm set to 30% Battery Saver, but also get the low battery warning, with a sound alarm, at 15%. I don't know whether you can change the latter.
Thanks for the reply, but I think you've misunderstood slightly.
I don't use the battery saver option. I just wondered if you can change the setting when the phone tells you that the battery is low, regardless of battery saving or not.
(Yes, I added a bit to my post just before you posted I imagine.)
You can disable. You need root, then g3 tweaksbox, then you can disable both the 15% and 5% notification, or just one.
Ok, cheers. Not sure I'm bothered enough about it to root, but I'll keep that in mind.
