Charge Cord and Power Plug
tech_fan
827
I am getting my OP7 Pro tomorrow. I need to get 2 additional USB-C cables and power plugs for my work and when I travel. I noticed that they are $50 on their website. Is there a cheaper alternative that works just as good? Can I just use a regular USB charge plug and USB-C cable or do I have to use theirs? I saw in their manual and on the One Plus website it states that I can only use their cables and plugs.
Thanks
There isn't a cheaper option that works just as well, but you can use any USB-C charger. You just won't get the Warp factor.
Thanks. So, i can use a Standard Anker IQ charger along with a standard USB-C cable to charge the device but, it wont charge as fast as the $50 Warp charger and cable, right?
Exactly!
How noticeable it will be depends on how you charge. You'll only miss Warp change if you're the kind of person who lets their battery drain low. If you're one of those people who constantly tops up you won't notice much difference. It's only REALLY fast between about 0% and 65%.
kiki2025
