newtda513 Well-known member Sep 24, 2011 198 1 18 Nov 8, 2014 #1 I lost my original charger that came with the tablet. At I need charge the tablet, what voltage charger should I be using to charge the tablet?
G Glenn234 Member Nov 22, 2013 10 0 0 Nov 8, 2014 #2 Almost any USB charger. Five point 1or 2. Your computer will work fine. My tablet usually charges around 800ma. Ron
newtda513 Well-known member Sep 24, 2011 198 1 18 Nov 8, 2014 #3 I don't it is the charger or the tablet but it is very slow charge
D drew_t Well-known member Dec 19, 2011 92 5 0 Nov 9, 2014 #4 The original charger is a 2 amp model. If you're trying to use a typical charger for a cellphone or Bluetooth accessory, it's probably rated at something between 500 mA (half amp) to 1 amp, and will take a long time to charge your N7.
N neonworm Well-known member Apr 10, 2013 2,757 0 0 Nov 9, 2014 #5 I recommend you purchase the official Nexus Charging Accessory: https://forums.androidcentral.com/e...s_wall?playredirect=true&hl=en&token=62WqhCNm
rxgadget Well-known member Aug 8, 2010 730 3 0 Nov 11, 2014 #6 neonworm said: I recommend you purchase the official Nexus Charging Accessory: https://forums.androidcentral.com/e...s_wall?playredirect=true&hl=en&token=XsgrsZZi Click to expand... Out of stock. I bought a couple 2 amp chargers, one is an Amazon brand and it charges my N7 (2012) fine. Our done when the micro USB doesn't fall out Sent using my Verizon Turbo charged 64GB Ballistic Nylon phone unfortunately with a case on back
