Chargers
GTvert90
673
18
I'm in need of a second charger. There's a few on Amazon that say they are compatible. Does anyone have any experience with any 3rd party chargers?
Make sure to get a magnetic one. I got this one buts it's currently out of stock.
Samsung Galaxy Watch Charger Stand, Boomba Replacement Charging Stand Charging Cradle Dock Adapter Holder Compatible for Samsung Galaxy Watch (46mm) https://www.amazon.com/dp/B07GWZPJG...ag=hawk-future-20&ascsubtag=UUacUvbUpU6431481
Avoid this one if possible
Samsung Galaxy Watch Charger Stand, Replacement Charging Stand Charging Cradle Dock Adapter Holder Compatible for Samsung Galaxy Watch (46mm/42mm) https://www.amazon.com/dp/B07H92ZKM...ag=hawk-future-20&ascsubtag=UUacUvbUpU6431481
It will work but it's a pain. It's not magnetic and you have to fiddle with it to get the watch to charge properly on it. If it isn't on perfectly you get the dreaded Use The Charger that came with the watch warning. I tossed mine in a drawer for emergencies. Then got the first one I mentioned.
I have a third party charger, and it does not work particularly well. It caused abnormal heating issues with my watch, and after a couple attempts I decided not to use it again to ensure that I don't damage my watch battery (thankfully my two attempts didn't seem to cause any permanent damage to the watch). Granted, I paid $13 for this thing so maybe you'd have better luck with a higher end charging cradle.
I recommend this charger from Samsung:
https://www.amazon.com/Samsung-Wire...ag=hawk-future-20&ascsubtag=UUacUvbUpU6432057
It's $38, which I admit is a little pricey for a charger, but it will charge either your Galaxy Watch, or any Qi-enabled phone (it'll charge Samsung phones with adaptive fast charging). I use this to charge my Galaxy Watch and have not experienced any issues.
tuananh3105
