Charging animation repeatedly playing after unplugging device
  • Start date Start date
A
Android Central Question
Hi, I'm using an LG Stylo 4 and I have a really particular problem.
When you plug in a USB-C charging cable to this device, a little animation plays at the bottom of the screen near the charging port while it briefly dims the screen. Seems harmless enough.
My problem comes in whenever I unplug the charger. The device repeatedly shows that animation, including the screen dimming, at random intervals when the device is unplugged. Restarting the device resolves the issue, but it comes back again whenever I plug in and unplug the device.
Additionally, when the battery usage screen is open, the Google Play Services entry will flicker to its long-form file name for 1 frame every time the charging animation plays.
Has anyone had this issue, if so, how did you fix it?
Welcome to Android Central! Make sure the charging port is clear of any debris by blowing it out with a can of compressed air, and also clean the contacts with a Q-tip dipped in rubbing alcohol.
uobuob
