Charging problem
gtn52
I charge my S3 mini overnight. 90% of the time it switches itself off during the night. Really annoying when you need the alarm in the morning! How can I stop it from doing this?
Thanks
Welcome to Android Central!
Hmm...well, if you don't get any other better suggestions consider doing a factory reset. That may bring it back into submission.
...and, if you have time, pop into the Introduction forum and introduce yourself.
Assuming that you're using an authorized charger and cable, this should never happen. If the Factory Reset doesn't pan out you should take it back to the local carrier store and ask for a replacement - this sounds like a problem with the hardware.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
Another good question is, does it shut off because of a low battery, then charge?
From a Sprint Moto X using AC forums app
^ Good point
