Charging Problems on my S4
Defining
3
For some reason, my phone does not charge when the screen is off. When I have a charger plugged in, I'll turn off the screen and all of a sudden my screen will turn back on and say that a charger is connected, just as if I connected a charger again. How do I fix this?
try different charge
take out the battery and rotate it on a flat surface , if it rotates then the battery is damaged
go to recovery and clear cache.
If it rotates? Don't get what you're saying.
Sometimes, when a battery goes bad, the internal cells rupture, and cause a bulge to appear in the battery. You see this when you hold the battery is up. Additionally, a bulge makes it able to spin like a top when placing the battery on a flat surface.
I'm not sure, cause I'm using a ZeroLemon Extended Battery.
xinyingt2
