Charging / usb issue
Xanth269
511
26
Hello all,
started to have an issue with my charging system after I used a Eton 2000 mah portable backup battery. it randomly shows the phone is charging when not plugged in. Also today I tried to plug the phone to the pc with the same USB cable I have been using for some time now, it will not recognize the phone. I tried android commander and it did not find it. I checked and usb debugging is on and the phone says connected as media device.
I have had an issue in past when I had fast charge turned on I had no access to the phone when plugged into the PC.
any thoughts to check?
Thanks..
OK folks,
tried this am and now the PC finds the phone, strange.. no reboot or any thing, just plugged cable into phone and there it was.
Adamsapple
