CHOETECH 39W 3-Port Wall Charger Review (USB C, USB A x2)
rpz3.14
312
48
This is a brief review of the Cheotech 3-Port Wall review, purchased at Amazon (Link). I received this device at a discount for review purposes.
I've used this charger for the past week to charge my Nexus 6p, my wife's Nexus 6 and my old Nexus 10 tablet. The USB C port charges very quickly, regardless of how many ports on in use. In my testing, it consistently pulled around 2.7 A (using Ampere to measure). The USB A ports also performed well, consistently pulling between 1.6 and 2.0 A. There was no humming or other noise, either during charging or with nothing plugged in.
The design and build of the charger is pretty good, also. The plastic housing is unremarkable, but sturdy. The plugs fold into the housing, which is a handy feature for transportation. The only downside is that the charger is a little tall, and may interfere with something plugged in above it (see the attached photo).IMG_20160212_162732.jpg
Overall, I am extremely happy with this charger.
Please post any questions or comments you have.
I too a very happy with my wall charger. Ampere shows it charging and the correct mAh and the device shows quick charging enabled. All in all, its a good purchase and you get your value out of it.
lahsfato
